共4页/75条首页上一页123下一页尾页
回复:75 阅读:16179
B1803少见乳腺肿物,鉴别诊断? (cqz-18, 5-7-2009)
楼主 发表于 2009-05-07 18:25|举报|关注(1)
about 60 y/f, right breast mass 2 cm by imaging, breast core biopsy.
1. Your differential diagnosis?
2. What will you do next?
Please do not just give a diagnosis. Your dx is a guess dx even though your diagnosis may be right.
As pathologists we should learn how to analyse our cases with logic thought.We should have differential dx for all cases in our mind even for the easy cases. We can use available sources (such as IHC, molecular methods, history, consultation) to rule in or rule out the differential dx, then make the final dx.
Learning the priniciple for diagnosis is much more important than learning a few cases.
  • 少见乳腺肿物,鉴别诊断? (cqz-18, 5-7-2009)图1
  • 少见乳腺肿物,鉴别诊断? (cqz-18, 5-7-2009)图2
标签:乳腺化生性癌 叶状肿瘤 平滑肌肉瘤 肉瘤 鉴别 ck7 VIM
Leiomyosarcoma of the breast(乳腺平滑肌肉瘤)
1 楼    发表于2009-05-07 18:33:00举报|引用
 200x
400x
lxyrppp 离线
经验:249
2 楼    发表于2009-05-07 18:54:00举报|引用
 MPNST?
zrj711 离线
经验:284
3 楼    发表于2009-05-07 19:44:00举报|引用
 化生性癌吗?需要更多证据低倍图呢!
thlcp 离线
经验:911
4 楼    发表于2009-05-07 20:00:00举报|引用
 肉瘤样癌?
cici 离线
经验:573
5 楼    发表于2009-05-07 20:06:00举报|引用
 梭形细胞,弥漫分布,异型明显,首先考虑肉瘤样癌,免疫组化上皮阴性再考虑真性肉瘤
亡羊补牢
6 楼    发表于2009-05-08 01:40:00举报|引用
以下是引用zrj711在2009-5-7 19:44:00的发言:
 化生性癌吗?需要更多证据低倍图呢!
This is breast core bx. The tumors grows with the similar pattern like above the photos. In other words the photos represent the lesion in the breast core. What information can you get from the low power?
byq 离线
粉蓝豆:129
经验:3229
7 楼    发表于2009-05-08 05:05:00举报|引用
以下是引用cici在2009-5-7 20:06:00的发言:
同感.
SOS991229 离线
粉蓝豆:1747
经验:1886
8 楼    发表于2009-05-08 21:31:00举报|引用
 梭形细胞,弥漫分布,异型明显,恶性分叶状肿瘤,需要做vimtin,s-100,desmin,ck7,ck20,villin等,请赵老师指导。
lideyan 离线
经验:78
9 楼    发表于2009-05-08 21:44:00举报|引用
 支持化生性癌,但需做免疫组化进一步证实。ck7,vimentin,ck20,s-100.
李德艳
10 楼    发表于2009-05-08 21:57:00举报|引用
“Learning the priniciple for diagnosis is much more important than learning a few cases.”
——Very correct !
11 楼    发表于2009-05-08 22:02:00举报|引用
 如果我遇到这样的病例,我的第一印象是:梭形细胞化生性癌---可以用CK7、CK8/18等确定其上皮性质;周围可能有原位癌成分;另外,梭形细胞癌也常标记肌上皮标记物(如P63、S-100、calponin等故需注意与肌上皮癌鉴别)。
当然一定要有其他鉴别诊断:1、恶性叶状肿瘤---寻找良性上皮成分;梭形细胞CK阴性而Vimentin阳性;或可有异源性分化(如骨、肌源性分化等)。2、乳腺间质肉瘤。3、乳腺非特异性软组织肉瘤。……
期待Dr.zhao的结果与分析。
12 楼    发表于2009-05-08 22:12:00举报|引用
 spindle cell carcinoma and malignant myoepithelima and fibrosarcoma and pholaddle tumor enter the differential diagnosis
13 楼    发表于2009-05-08 22:13:00举报|引用
 malignant myoepithelioma will be the first choice
14 楼    发表于2009-05-10 13:55:00举报|引用
本帖最后由 于 2009-05-10 13:59:00 编辑 Most above analysese are reasonable.
IHC: AE1/AE3, cam 5.2 negative
Photo is vimentin stain
15 楼    发表于2009-05-10 14:01:00举报|引用
本帖最后由 于 2009-05-10 14:03:00 编辑 Now what is your dx or ddx?
What is the next?
Will you sign out the case now?
16 楼    发表于2009-05-10 14:01:00举报|引用
常思一二三 离线
经验:87
17 楼    发表于2009-05-10 20:01:00举报|引用
 恶性叶状肿瘤
18 楼    发表于2009-05-10 20:41:00举报|引用
 只有两个视野要一下子做出正确诊断是很困难的,我想Dr.zhao主要目的是让大家谈一下你的诊断思路,锻炼一下观察能力,和分析问题解决问题的能力。
仔细观察一下第一张图,似乎有骨样组织?
我处理疑难病例的做法是:“反复看,查文献,多取材,做特免,实在不行请外援”。反复观察每一张切片的每一个角落、多取材和深切是常用的手段。
19 楼    发表于2009-05-10 20:47:00举报|引用
 化生性癌,恶性叶状肉瘤
20 楼    发表于2009-05-10 21:22:00举报|引用
笃(du)行者 :“反复看,查文献,多取材,做特免,实在不行请外援”。Very good. I think I will not forget the word "笃".
This case was a breast core biopsy, only one tissue block. The photo represents the lesion in the available specimen.
More IHC results: ER, PR, Her2 negative.
Will you sing out the case (?diagnosis) or do more study? If you want to work more on this case, what will you do? What immunostains will you order? Why? You can order the immunostains. I am your lab technologists and do the stains for you and tell your the stain results.
I am in Los Angeles to enjoy my vocation time. Glad to work for this case with your guys.
cz
回复:75 阅读:16179
