共1页/8条首页上一页1下一页尾页
回复:40 阅读:7271
B1813乳房肿块, 少见,但easy to make dx (czq-19)
楼主 发表于 2009-05-20 10:28|举报|关注(0)
  • 乳房肿块, 少见,但easy to make dx (czq-19)图1
  • 乳房肿块, 少见,但easy to make dx (czq-19)图2
  • 乳房肿块, 少见,但easy to make dx (czq-19)图3
  • 乳房肿块, 少见,但easy to make dx (czq-19)图4
  • 乳房肿块, 少见,但easy to make dx (czq-19)图5
  • 乳房肿块, 少见,但easy to make dx (czq-19)图6
标签:乳腺腺肌上皮瘤
1 楼    发表于2009-06-12 02:00:00举报|引用
  有福不在忙 Very accurative translation. Thanks. You may earn more money if you change your job as a translator. Just kiding. cz
2 楼    发表于2009-06-11 12:56:00举报|引用
 For rare or difficult cases, these general text books are not very useful.
3 楼    发表于2009-06-09 18:58:00举报|引用
 Thank  猪猪 and 天山望月 for above data.
I agree that no clear definition for benign and malignant AME. Can some one do a literature search to see if there are some papers to describe the difference of the lesions?
4 楼    发表于2009-06-02 05:47:00举报|引用
 Thank above. I love your web name.
5 楼    发表于2009-05-31 20:03:00举报|引用
 There are many cases in this website. It is meaningless if we see the photos and give a guess diagnosis. It is easy to have many classic pictures for all lesions in the text books, CD et al.
The advantage here online is that you can think over the differential dx, summary the cases, discuss the cases and share your oppinion with all others. We all are participants, not only readers.
6 楼    发表于2009-05-31 19:50:00举报|引用
 Quickly review above interpretation from all of you. It is good almost all of you got the correct point. Clearly it is a adenomyoepithelial lesion, two cell component.
Adenomyoepithelioma (AME) of the breast is an uncommon tumor characterized by the presence of both epithelial and myoepithelial cells; its first full description was published in 1970 by Hamperl.
Could some one sumarry the features of benign and maligant AME? I have not check books or literatures yet. So In fact I am not clear about the definition now. Hope some one will do the search and share with us here. Thanks, cz
7 楼    发表于2009-05-31 19:32:00举报|引用
 Thank  天山望月's detailed analysis. This is AFIP case. age about 50, tumor size 1.5 cm. IHC showed myoepthelial cell proliferation.
8 楼    发表于2009-05-20 10:31:00举报|引用
 50 y/f with breast mass lesion 2.5  cm.
1-2 40x
3-4 200x
5-6 400x
回复:40 阅读:7271
共1页/8条首页上一页1下一页尾页
