共2页/35条首页上一页12下一页尾页
回复:35 阅读:6183
肝脏病理科在免疫组化中的应用 欢迎大家讨论
wyp54007 离线
经验:5
楼主 发表于 2009-05-25 16:40|举报|关注(0)
Librahsu 离线
经验:73
1 楼    发表于2009-05-28 09:45:00举报|引用
 我觉得讨论题目应该改一改- 免疫组化在肝脏病理方面的应有-比较好一些。
chinaroc 离线
粉蓝豆:924
经验:1343
2 楼    发表于2009-05-29 14:11:00举报|引用
 确实这是一个很有意义的话题。以往仅侧重于肝脏癌的鉴别,其实可以做得更多。
用心做事、真情做人!
fangg 离线
粉蓝豆:44
经验:1863
3 楼    发表于2009-07-01 13:44:00举报|引用
 先提供一篇文献再说:
Agrin and CD34 Immunohistochemistry for the Discrimination of Benign Versus Malignant Hepatocellular Lesions
Agrin is a recently identified proteoglycan component of vascular and bile duct basement membranes in the liver. The selective deposition of agrin in hepatocellular carcinoma (HCC) microvessels versus sinusoidal walls prompted us to investigate the utility of agrin immunohistochemistry (IHC) in detecting malignant hepatocellular lesions. We focused on the differential diagnostic problems often presented by hepatocellular adenomas (HCAs) and dysplastic nodules. IHC for agrin was performed on 138 formalin-fixed, paraffin-embedded surgical specimens from 93 patients, including cirrhotic liver tissues (25), focal nodular hyperplasia (10), large regenerative nodules (8), low-grade (23) and high-grade (7) dysplastic nodules, small HCC (8), HCC (27), and HCA (30). Agrin immunostaining was compared with that of CD34 and, in selected cases, to glypican-3. The combination of agrin and CD34 sensitively (0.94) and specifically (0.93) identified lesions judged previously as malignant by histology. The majority of benign lesions were clearly agrin-negative, whereas the strength and extent of agrin IHC faithfully reflected dysplasia in atypical HCAs and in high-grade dysplastic nodules. Malignant lesions were uniformly positive. In conclusion, as agrin is highly selective for tumor blood vessels, IHC for agrin facilitates the discrimination of benign and malignant hepatocellular lesions. Moreover, whereas glypican-3 in some HCCs may appear in few scattered cells only, agrin is diffusely deposited in virtually all malignant lesions, which may prove advantageous in the evaluation of small specimens such as core biopsies.
The American Journal of Surgical Pathology:June2009 Volume33 Issue6 pp874-885
境随心转
shiqian 离线
经验:191
4 楼    发表于2009-08-08 22:54:00举报|引用
 非常好的论题!
我们鉴别HCC,需要做CD34,CD68,CD8/18,AFP,HEP,GPC-3等。
mousecjn 离线
经验:18
5 楼    发表于2009-08-11 23:42:00举报|引用
以下是引用shiqian在2009-8-8 22:54:00的发言:
 非常好的论题!
请问shiqian老师及各位老师:CD68,GPC-3在HCC鉴别中的作用?能否具体说说,谢谢!
Rookie 离线
6 楼    发表于2009-09-04 22:42:00举报|引用
 含有Beta-catenin也很有用
ping117 离线
经验:177
7 楼    发表于2009-09-13 11:10:00举报|引用
 我们医院主要是做肝穿,确定肝炎的分级,FGS分级,区分乙肝,自免肝,药物肝,脂肪肝,也有肝癌。免疫组化主要是,HBVSAg,HBVCAg,CK19,CD34,另加网染,masson.还望各位前辈多加指点
chinaroc 离线
粉蓝豆:924
经验:1343
8 楼    发表于2009-09-13 23:26:00举报|引用
 肝脏病理学中免疫组化染色是很重要的。在Washington University虽然特殊染色作为最重要的依据(Masson, PAS, 铜/铁染色),CK19是最重要的免疫组化指标(观察小胆管的变化)。而 具体的免疫组化的应用根据诊断的目的,个人粗略的分类如下:
1.病毒性肝炎病变:病毒学的检测,如HBS-Ag,CMV,EBV等;
2.自身免疫性肝炎或肝脏移植:PBS的小胆管改变,CK19;
3.肝脏代谢应疾病:如范素等的染色;
4.肝脏肿瘤,CD34,CK,特异性标记物(ER\PR\MCU\TTF-1等)系列鉴别转移性肿瘤;
用心做事、真情做人!
shiqian 离线
经验:191
9 楼    发表于2009-09-14 22:03:00举报|引用
 回答6楼老师提问:
 CD68在相对正常肝脏内,可以使Kupffer细胞染色,在肝窦内肝细胞之间排列较规则,
 而HCC时肿瘤细胞间没有此细胞,可有散在不规则的吞噬细胞阳性,与正常形态及排列均不同,可供参考。
 GPC-3我们用于染HCC的肿瘤细胞,效果不错,特别是极高分化的HCC,很有价值,
 如果再配上4楼老师提供的Agrin ,全无敌!
Rookie 离线
10 楼    发表于2009-09-25 21:07:00举报|引用
慧海拾穗 离线
粉蓝豆:406
经验:148
11 楼    发表于2009-09-26 09:10:00举报|引用
学习了,谢谢!
不要埋怨昨天,要立足今天,创造明天!愿大家医路走好!
jswxq1 离线
经验:17
12 楼    发表于2009-10-10 08:13:00举报|引用
 学习学习!
xianren 离线
粉蓝豆:449
经验:1507
13 楼    发表于2009-10-10 08:35:00举报|引用
ping117 离线
经验:177
14 楼    发表于2009-10-30 20:23:00举报|引用
     请问各位前辈,现在在诊断自身免疫性肝炎方面,对肝穿的组织有没有适合做免疫组化的抗体??在诊断过程中,汇管区浆细胞浸润不是太明显,不知是浆细胞不明显,还是就根本没浆细胞??晚辈想标记浆细胞,用CD19,CD20,CD22行吗??请教各位
林子1003 离线
粉蓝豆:23
经验:420
15 楼    发表于2009-11-24 18:58:00举报|引用
以下是引用shiqian在2009-9-14 22:03:00的发言:
 回答6楼老师提问:
学习、学习、再学习!
woniu 离线
经验:558
16 楼    发表于2009-11-27 20:06:00举报|引用
 学习了,谢谢!
woniu
liuhuier 离线
经验:2
17 楼    发表于2009-12-02 22:44:00举报|引用
染HCV有比较好的抗体吗?
shuanlong 离线
粉蓝豆:4694
经验:9037
18 楼    发表于2009-12-03 19:48:00举报|引用
benben520sps 离线
粉蓝豆:568
经验:1254
19 楼    发表于2009-12-17 21:27:00举报|引用
以下是引用chinaroc在2009-9-13 23:26:00的发言:
3.肝脏代谢应疾病:如范素等的染色;
zsy720121 离线
经验:38
20 楼    发表于2009-12-21 15:13:00举报|引用
 可标轻链和重链
回复:35 阅读:6183
共2页/35条首页上一页12下一页尾页
