共1页/13条首页上一页1下一页尾页
回复:32 阅读:6733
B2945Clinical and biological significance of E-cadherin protein expression in invasive lobular carcinom..
楼主 发表于 2010-11-11 04:09|举报|关注(0)
Am J Surg Pathol. 2010 Oct;34(10):1472-9.
Clinical and biological significance of E-cadherin protein expression in invasive lobular carcinoma of the breast.
Rakha EA, Patel A, Powe DG, Benhasouna A, Green AR, Lambros MB, Reis-Filho JS, Ellis IO.
Department of Histopathology, Nottingham University Hospitals NHS Trust, UK. emadrakha@yahoo.com
BACKGROUND: Although virtually all cases of lobular carcinoma in situ lack E-cadherin expression, a proportion of morphologically typical invasive lobular carcinomas (ILCs) retain its expression. The frequency and significance of E-cadherin expression in ILC remain to be elucidated. In this study, we have assessed E-cadherin protein expression in a well-characterized series of histologically defined ILC (239 cases) with a long-term clinical follow-up to determine the frequency, clinical and biological significance of its expression. E-cadherin-positive ILCs (ILC+) were subsequently examined to assess the expression of component members of the E-cadherin membrane complex (E-cadherin, p120, α, β, and γ-catenins) to determine its integrity.
RESULTS: Thirty-eight ILC cases (16%) showed positive E-cadherin expression (ILC+). Membranous expression of E-cadherin was mainly circumferential with frequent coexisting perimembranous cytoplasmic expression. No association between E-cadherin expression and any of the clinicopathologic variables, immunophenotype, or tumor behavior was identified, apart from an association with lobular histologic subtype and vascular invasion. Analysis of the E-cadherin-catenin complex showed abnormal expression of one or more of the catenin complex members in the majority of cases. The most frequent observation was the diffuse cytoplasmic expression of catenins, in particular p120, which showed similar expression to that reported in E-cadherin-negative ILCs.
CONCLUSIONS: These results provide evidence that E-cadherin is expressed in a proportion of ILC, however, unlike ductal carcinoma, its expression seems to be of limited significance and it is usually associated with evidence of impaired integrity of the E-cadherin-catenin membrane complex. Our data offer a possible explanation for the presence but lack functionality of E-cadherin in some cases of ILC and imply that immunohistochemical expression of E-cadherin per se in ILC histologic phenotypic tumors should not preclude its diagnosis.
PMID: 20871222 [PubMed - indexed for MEDLINE]
标签:乳腺浸润性小叶癌 E-cadherin p120
1 楼    发表于2010-12-04 03:47:00举报|引用
 H&E favor lobular lesion; E-cad-membrane positive; P120 cytoplasmic strong stains.
It is better to be called focal ALH.
粉蓝医疗科技(杭州)有限公司官网入口 times p120 stain can be helpful. This is why we often do double stains for possible lobular lesions.
2 楼    发表于2010-12-04 03:42:00举报|引用
 f1-E-cad
f2 P120
3 楼    发表于2010-12-04 03:37:00举报|引用
Have a case of core bx and share with you
core bx for microcalcifications. Benign except for the area below
 200x
400x
4 楼    发表于2010-11-25 04:39:00举报|引用
 Check it  in the Google. Do you know the name of histological grading system on breast ca?
5 楼    发表于2010-11-16 03:45:00举报|引用
 Thank viivi薇 for your translation
6 楼    发表于2010-11-16 03:28:00举报|引用
 Pay attention to the authors. They are from Nottingham. Hope you know Nottingham
7 楼    发表于2010-11-11 04:31:00举报|引用
 It is difficult to paste the powerpoint slides. I stop here. You can find the original paper to read if you are interested. thanks, cz
8 楼    发表于2010-11-11 04:30:00举报|引用
 Above photos-E-cadherin: Authors interpretate D as invasive ductal ca only. Allother photos are invasive lobular ca.
Do you agree?
9 楼    发表于2010-11-11 04:25:00举报|引用
 photos
A-D: ILC with circumferential staining; E: ILC with intercellular staining;
F: IDC with intercellular staining
10 楼    发表于2010-11-11 04:22:00举报|引用
本帖最后由 于 2010-11-28 17:38:00 编辑 E-cadherin Function
For E-cadherin function in epithelial cell polarity and epithelial tissue integrity, the cytoplasmic tail of E-cadherin must be associated with cateninsa, b, and g-catenins and p120 Together these appear to play a role in signal transduction
11 楼    发表于2010-11-11 04:19:00举报|引用
本帖最后由 于 2010-11-28 07:02:00 编辑 Introduction
E-cadherin Calcium-dependent homophilic adhesion molecule Implicated in numerous cellular functions Controlling morphogenesis Suppressing tumor invasion and metastasis
12 楼    发表于2010-11-11 04:18:00举报|引用
Clinical and Biological Significance of E-cadherin Protein Expression in Invasive Lobular Carcinoma of the Breast (Am J Surg Pathol 2010;34:1472–1479)
Emad A. Rakha, FRCPath,* Arjun Patel, BSc,* Des G. Powe, PhD,* Ahmed Benhasouna, MSc,* Andrew R. Green, PhD,* Maryou B. Lambros, PhD, Jorge S. Reis-Filho, FRCPath, and Ian O. Ellis, FRCPath* (Nottingham)
Fellows Conference At Magee
13 楼    发表于2010-11-11 04:16:00举报|引用
 It is debatable for dx of invasive lobular ca. It should be based on morphology or IHC.  This is an interesting paper. Our breast fellow Dr. James Kraus showed it in our weekly morning fellow journal club.
I paste his powerpoint here for some ones who are interested.
回复:32 阅读:6733
共1页/13条首页上一页1下一页尾页
