共2页/32条首页上一页12下一页尾页
回复:32 阅读:7898
B2945Clinical and biological significance of E-cadherin protein expression in invasive lobular carcinom..
楼主 发表于 2010-11-11 04:09|举报|关注(0)
Am J Surg Pathol. 2010 Oct;34(10):1472-9.
Clinical and biological significance of E-cadherin protein expression in invasive lobular carcinoma of the breast.
Rakha EA, Patel A, Powe DG, Benhasouna A, Green AR, Lambros MB, Reis-Filho JS, Ellis IO.
Department of Histopathology, Nottingham University Hospitals NHS Trust, UK. emadrakha@yahoo.com
BACKGROUND: Although virtually all cases of lobular carcinoma in situ lack E-cadherin expression, a proportion of morphologically typical invasive lobular carcinomas (ILCs) retain its expression. The frequency and significance of E-cadherin expression in ILC remain to be elucidated. In this study, we have assessed E-cadherin protein expression in a well-characterized series of histologically defined ILC (239 cases) with a long-term clinical follow-up to determine the frequency, clinical and biological significance of its expression. E-cadherin-positive ILCs (ILC+) were subsequently examined to assess the expression of component members of the E-cadherin membrane complex (E-cadherin, p120, α, β, and γ-catenins) to determine its integrity.
RESULTS: Thirty-eight ILC cases (16%) showed positive E-cadherin expression (ILC+). Membranous expression of E-cadherin was mainly circumferential with frequent coexisting perimembranous cytoplasmic expression. No association between E-cadherin expression and any of the clinicopathologic variables, immunophenotype, or tumor behavior was identified, apart from an association with lobular histologic subtype and vascular invasion. Analysis of the E-cadherin-catenin complex showed abnormal expression of one or more of the catenin complex members in the majority of cases. The most frequent observation was the diffuse cytoplasmic expression of catenins, in particular p120, which showed similar expression to that reported in E-cadherin-negative ILCs.
CONCLUSIONS: These results provide evidence that E-cadherin is expressed in a proportion of ILC, however, unlike ductal carcinoma, its expression seems to be of limited significance and it is usually associated with evidence of impaired integrity of the E-cadherin-catenin membrane complex. Our data offer a possible explanation for the presence but lack functionality of E-cadherin in some cases of ILC and imply that immunohistochemical expression of E-cadherin per se in ILC histologic phenotypic tumors should not preclude its diagnosis.
PMID: 20871222 [PubMed - indexed for MEDLINE]
标签:乳腺浸润性小叶癌 E-cadherin p120
21 楼    发表于2010-12-01 17:49:00举报|引用
 谢谢楼上各位老师,以后在工作中注意这方面的情况。
hanyuxie 离线
粉蓝豆:41
经验:59
22 楼    发表于2010-12-01 20:22:00举报|引用
 醍醐灌顶,0茅塞顿开
青青子矜 离线
经验:1387
23 楼    发表于2010-12-02 22:39:00举报|引用
 Thank Dr.zhao for sharing so interesting question.But it is a pity not to get the full text.
24 楼    发表于2010-12-03 20:45:00举报|引用
 Thank Dr.cqzhao again for your kind instruction and help!
亚梦 离线
经验:275
25 楼    发表于2010-12-03 22:18:00举报|引用
 THx!
26 楼    发表于2010-12-04 03:37:00举报|引用
Have a case of core bx and share with you
core bx for microcalcifications. Benign except for the area below
 200x
400x
27 楼    发表于2010-12-04 03:42:00举报|引用
 f1-E-cad
f2 P120
28 楼    发表于2010-12-04 03:47:00举报|引用
 H&E favor lobular lesion; E-cad-membrane positive; P120 cytoplasmic strong stains.
It is better to be called focal ALH.
粉蓝医疗科技(杭州)有限公司官网入口 times p120 stain can be helpful. This is why we often do double stains for possible lobular lesions.
SOS991229 离线
粉蓝豆:1747
经验:1886
29 楼    发表于2010-12-04 20:00:00举报|引用
 谢谢赵老师及金主任的详细讲解,在日常工作中,发现这些问题不知道如何应对,现在豁然开朗!谢谢,一定整理下来好好学习!
ths35 离线
粉蓝豆:6540
经验:765
30 楼    发表于2010-12-04 23:09:00举报|引用
 谢谢老师对用E-cad及P120区分小叶癌与导管癌的讲解,受益匪浅。
31 楼    发表于2010-12-05 22:13:00举报|引用
 赵老师总是给我们引导新知识、新动向、新潮流。谢谢!
xingyunliushui 离线
经验:1915
32 楼    发表于2010-12-06 19:14:00举报|引用
E-cadherin Calcium-dependent homophilic adhesion molecule Implicated in numerous cellular functions Controlling morphogenesis Suppressing tumor invasion and metastasis
回复:32 阅读:7898
共2页/32条首页上一页12下一页尾页
