回复:20 阅读:6211
分享:孙博士在Cell Oncology发表的学术文章之一
芸芸众生 离线
经验:244
楼主 发表于 2011-09-09 23:54|举报|关注(0)
Detection of cervical cancer and high grade neoplastic lesions by a combination of liquid-based sampling preparation and DNA measurements using automated image cytometry.
OBJECTIVE:
To establish if measurements of DNA ploidy could be used to assist cytopathologists and cytotechnologists in population based cervical cancer screening programs in countries where manually reading the slides is impossible due to the lack of sufficient skilled cytotechnologists. The goal of such program is to identify only clinically significant lesions, i.e. those where a clinical intervention to remove the lesion is required immediately.
STUDY DESIGN:
A total of 9905 women were enrolled in the study. Cervical samples were taken with a cervix brush that was then placed into a fixative solution. The cells were separated from mucus by mechanical and chemical treatment and then deposited onto microscope slides by a cytocentrifuge. Two slides were prepared from each case; one slide was stained by Papanicolaou stain for manual cytology examination, while the other slide was stained by a DNA specific stain. The latter slide was used to determine the relative amount of DNA in the cell nuclei.
RESULTS:
A total of 876 women were followed by colposcopy examination where biopsies were taken from the visible lesions or from suspicious areas and histopathology diagnosed 459 as normal or benign cases, 325 as CIN1, 36 as CIN2, 25 as CIN3/CIS, and 31 as invasive cancer. Of these 876 cases, manual cytology called 655 normal or ASCUS, 197 as LSIL, 16 cases as HSIL, and 8 as cancer. DNA measurements found 704 cases having no cells with DNA greater than 5c, 98 cases where there were 1 or 2 cells having DNA amount greater than 5c, and 74 cases where there were 3 or more cells having DNA amount greater than 5c. If manual cytology were to be used to refer all cases of HSIL and cancer to colposcopy and biopsy, 23 lesions that had to be removed would have been discovered (2 CIN2, 11 CIN3/CIS, and 10 cancers), for a sensitivity of 25.0+/-5.2% at specificity of 99.9+/-0.1%. If DNA assisted cytology were to be used instead, and all cases having 3 or more cells with DNA amount greater than 5c were to be referred to colposcopy and biopsy, then 50 lesions that had to be removed would have been discovered (10 CIN2, 15 CIN3/CIS and 25 cancers) for the sensitivity of 54.3+/-6.2% at specificity of 96.9+/-0.6%.
CONCLUSIONS:
The study suggests that screening for high grade cervical neoplastic lesions and cervical cancer by DNA assisted cytology could be implemented with minimal use of skilled cytotechnologists, at least in those countries where it would be difficult to introduce population based screening for cervical cancer due to the lack of availability of such skilled cytotechnologists.
Keywords
Cervical intraepithelial neoplasia (CIN), liquid based sample preparation, image cytometry, DNA ploidy, cytotechnologist shortage, cytology, sensitivity, specificity, invasive cancer
回复:20 阅读:6211
