共1页/20条首页上一页1下一页尾页
回复:20 阅读:6464
罕见的病例分享
kangwang2010 离线
经验:590
楼主 发表于 2011-12-10 10:47|举报|关注(9)
  • 罕见的病例分享图1
  • 罕见的病例分享图2
  • 罕见的病例分享图3
  • 罕见的病例分享图4
  • 罕见的病例分享图5
  • 罕见的病例分享图6
  • 罕见的病例分享图7
  • 罕见的病例分享图8
  • 罕见的病例分享图9
  • 罕见的病例分享图10
  • 罕见的病例分享图11
  • 罕见的病例分享图12
男, 5 个月,发现颈部肿物一周,近来有明显增大,淡灰色、软组织一块,整个肿物表面及剖面含大量黏液,大小约 5.5X3.5X2.0cm
镜下见大片粘液背景中散在许多小细胞,有多量微囊形成。
免疫组化结果:s-100-), syn-), Des -), SMA-), KI6740%+)。
标签:头颈部软组织肿瘤一例
有时候,称赞别人也是一种美德!
kangwang2010 离线
经验:590
1 楼    发表于2011-12-13 08:44:09举报|引用
其实是挺好的病例,怎么没人回复,讨论讨论呢?本例是国外专家会诊后才得出的结论,我们也是不认识。
希望大家热烈讨论,明天我会把结果和文献上传,大家一起学习啊!
有时候,称赞别人也是一种美德!
刀尖上的舞者 离线
粉蓝豆:84
经验:3356
2 楼    发表于2011-12-13 21:24:00举报|引用
我可是大力支持你了,不但给你加了三分,而且还把你的帖子设置成了精华帖子。
这个病例还真不知道从什么地方下手分析、学习了
zhangxia..
3 楼    发表于2011-12-14 07:26:12举报|引用
脂母
haozhaox..
haozhaoxing 离线
粉蓝豆:51
经验:1323
4 楼    发表于2011-12-14 08:08:39举报|引用
脂母
厚积薄发
kangwang2010 离线
经验:590
5 楼    发表于2011-12-14 09:38:40举报|引用
 结果:考虑为Primitive_Myxoid_Mesenchymal_Tumor_of_Infancy  婴儿原始黏液性间叶肿瘤。本例经澳太中心软组织学会主席Allen教授会诊。
Gross Pathology
The six primary tumors were unencapsulated and
had a multinodular but demarcated appearance with
focal infiltrative growth. The cut surface was white with
fleshy central areas and a firm periphery. Tumor diameter
ranged from 2.5 to 15.0 cm, with a mean of 8.8 cm.
Light Microscopy
All tumors were characterized histologically by a
diffuse growth of primitive spindled, polygonal, and
round cells in a myxoid background (Figs. 1A–D). The
tumor cells were often arranged in a vaguely nodular
pattern with a peripheral collagenized stroma and greater
cellularity at the periphery. Cellularity was low to
moderate. A delicate vascular network with a lacy
appearance was seen in many areas. Medium-sized
arterioles and venules surrounded by a cuff of densely
packed tumor cells were randomly distributed within the
tumors. The tumor cells had bland uniform nuclei with
even chromatin, inconspicuous nucleoli, and variable
amounts of pale eosinophilic to clear vacuolated cytoplasm
(Fig. 1E). In some areas, the vacuolated mesenchymal
cells were arranged in small aggregates. An Alcian
blue stain in 1 case demonstrated cytoplasmic acid mucins
in the vacuolated cells. Highly cellular areas were located
at the periphery of tumor nodules and were composed of
spindle cells arranged in bundles or fascicles with a focal
herringbone pattern (Fig. 1F). Infiltrative growth into
adjacent soft tissue was noted in 3 cases (Fig. 1G). In
three tumors, small cystic spaces were noted and were
lined by tumor cells and contained finely granular
eosinophilic material with a degenerative appearance
(Fig. 1H). Necrosis was identified in 1 case. An
inflammatory infiltrate was absent to sparse. The mitotic
rate varied from less than 1 to 10 mitoses per 10 high
power fields, with a mean of 4 mitoses per 10 high power
fields. No atypical mitoses were observed.
In 2 cases, slides were available from recurrences.
The recurrent tumors had increased cellularity and
increased cellular atypia in comparison with the original
tumors. The recurrent tumor cells were sometimes
elongated or epithelioid and arranged in clusters or
slender fascicles had pale to clear cytoplasm, and had
darker chromatin and more prominent nucleoli.
Immunohistochemistry
Results of immunohistochemical stains are summarized
in Table 2. The tumors showed diffuse reactivity
for vimentin and no reactivity for smooth muscle actin,
muscle specific actin, desmin, S-100 protein, myogenin,
cytokeratin, or bcl-2. Two cases showed indistinct weak
cytoplasmic CD99 reactivity. CD31 and CD34 stains
highlighted the delicate vascular background (Fig. 2) but
did not decorate tumor cell.
Ultrastructural Findings
Electron microscopy was available in 3 cases. All
showed a homogeneous population of poorly differentiated
fibroblasts with nuclei characterized by coarsely
distributed chromatin and cytoplasm devoid of intermediate
filaments, but with Golgi apparatus, free ribosomes,
scanty rough endoplasmic reticulum, and rare
hemidesmosomes and lysosomes (Fig. 3). The tumor cells
were noncohesive and embedded in a collagen-containing
matrix.
Molecular and Cytogenetic Results
Case nos. 1, 2, 3, and 6 were negative for the ETV6-
NTRK3 gene fusion by RT-PCR (2 cases with frozen
tissue and 2 cases with paraffin-embedded samples).
Cytogenetic analysis of tumor tissue from case no. 1
revealed 46, X der (Y)t(Y;9)(q12;p11) der (9)t(3;Y;9)
(p13;q12;p11) or t(3;9)(p12;p11), der (18)t(1;18)(q12;q23).
Cytogenetic analysis of tumor tissue from case no. 2
showed a 46, XY karyotype.
Little ..
有时候,称赞别人也是一种美德!
kangwang2010 离线
经验:590
6 楼    发表于2011-12-14 12:34:24举报|引用
引用 2 楼 刀尖上的舞者 在 2011-12-13 21:24:00 的发言:
谢谢支持!有好东西就应该大家分享!
有时候,称赞别人也是一种美德!
刀尖上的舞者 离线
粉蓝豆:84
经验:3356
7 楼    发表于2011-12-15 19:38:45举报|引用
您辛苦了
molly011 在线
粉蓝豆:244
经验:1818
8 楼    发表于2012-04-20 22:13:28举报|引用
学习啦,盼望楼主更多的好病例分享
稳扎稳打,稳中求胜
白桦林 离线
粉蓝豆:419
经验:1398
9 楼    发表于2012-04-25 22:25:38举报|引用
罕见,好病例!
蓝宝石6628 离线
粉蓝豆:321
经验:17245
10 楼    发表于2012-04-26 08:12:43举报|引用
从未见过的好病例,学习了。謝謝!
耶稣门徒..
乐观向上,不断进取!
lcyxxm 离线
经验:14041
11 楼    发表于2012-05-01 10:23:30举报|引用
我以为是脂肉?
fengrunlin123 离线
经验:33
12 楼    发表于2016-11-18 17:39:50举报|引用
这个好难,感谢老师的分享,谢谢
♀西瓜♂ 离线
粉蓝豆:50
经验:2632
13 楼    发表于2017-09-15 15:51:28举报|引用
 没见过 学习了!!
缺口 离线
粉蓝豆:207
经验:3944
14 楼    发表于2017-12-29 15:57:00举报|引用
 学习了 谢谢您的分享!
小爱因斯坦 在线
经验:43
15 楼    发表于2017-12-30 12:57:10举报|引用
来自iPhone 返回顶部 | 快捷回复
wowa 离线
粉蓝豆:268
经验:8135
16 楼    发表于2018-06-13 09:53:51举报|引用
whyang315 离线
粉蓝豆:416
经验:8989
17 楼    发表于2018-06-13 10:02:20举报|引用
 目的 探讨婴儿原始黏液样间叶性肿瘤(PMMTI)的临床病理学特征、免疫表型和鉴别诊断.方法 回顾性分析3例PMMTI的临床资料、病理学形态和免疫学表型.结果 男性2例,女性1例,年龄分别为4岁、2d和3个月,均因家长发现肿块就诊,2例位于颈部,1例位于腰部,肿块最大径分别为6.5、5.5、2.8 cm.镜下肿瘤由小卵圆形、短梭形和小多边形的瘤细胞组成,胞质稀少嗜伊红色或呈空泡状,瘤细胞轻度异型性,核分裂象(0 ~2)/10 HPF.瘤细胞呈弥漫性生长,部分区域呈结节状分布,结节周边为胶原化基质.肿瘤间质呈黏液样,富含纤细的血管,1例部分区域可见小囊腔样结构.免疫组织化学染色显示瘤细胞主要表达波形蛋白,不表达平滑肌肌动蛋白、结蛋白、肌生成素、S-100蛋白、CD34和细胞角蛋白.3例均行手术切除,1例术后复发2次,与原发肿瘤相比,复发肿瘤中瘤细胞密度明显增高,异型性明显,核分裂象易见(10/10 HPF),该患儿2年后死亡;另2例术后无瘤生存.结论 PMMTI是一种好发于婴儿的少见软组织肿瘤,由原始间叶性细胞和黏液样基质组成,主要发生于躯干、头颈部和四肢,切除不净易复发,极少数可发生转移或导致患儿死亡.熟悉这一新病种有助于避免将其误诊为先天性纤维肉瘤和脂肪母细胞瘤等好发于婴幼儿的间叶性肿瘤.
shadow8266 离线
粉蓝豆:954
经验:89
18 楼    发表于2018-06-13 11:21:53举报|引用
好病例!学习了,一开始以为是脂肪源性的恶性肿瘤,没想到s-100还是阴性的
107967594@qq.com 离线
粉蓝豆:1160
经验:419
19 楼    发表于2024-09-18 10:26:17举报|引用
 是图片太大了还是怎么回事,点击图片打不开
lei 离线
粉蓝豆:36
经验:1228
20 楼    发表于2024-09-18 16:52:44举报|引用
 国外工作还是做的细……
回复:20 阅读:6464
共1页/20条首页上一页1下一页尾页
