共1页/20条首页上一页1下一页尾页
回复:20 阅读:6210
分享:孙博士在Cell Oncology发表的学术文章之一
芸芸众生 离线
经验:244
楼主 发表于 2011-09-09 23:54|举报|关注(0)
Detection of cervical cancer and high grade neoplastic lesions by a combination of liquid-based sampling preparation and DNA measurements using automated image cytometry.
OBJECTIVE:
To establish if measurements of DNA ploidy could be used to assist cytopathologists and cytotechnologists in population based cervical cancer screening programs in countries where manually reading the slides is impossible due to the lack of sufficient skilled cytotechnologists. The goal of such program is to identify only clinically significant lesions, i.e. those where a clinical intervention to remove the lesion is required immediately.
STUDY DESIGN:
A total of 9905 women were enrolled in the study. Cervical samples were taken with a cervix brush that was then placed into a fixative solution. The cells were separated from mucus by mechanical and chemical treatment and then deposited onto microscope slides by a cytocentrifuge. Two slides were prepared from each case; one slide was stained by Papanicolaou stain for manual cytology examination, while the other slide was stained by a DNA specific stain. The latter slide was used to determine the relative amount of DNA in the cell nuclei.
RESULTS:
A total of 876 women were followed by colposcopy examination where biopsies were taken from the visible lesions or from suspicious areas and histopathology diagnosed 459 as normal or benign cases, 325 as CIN1, 36 as CIN2, 25 as CIN3/CIS, and 31 as invasive cancer. Of these 876 cases, manual cytology called 655 normal or ASCUS, 197 as LSIL, 16 cases as HSIL, and 8 as cancer. DNA measurements found 704 cases having no cells with DNA greater than 5c, 98 cases where there were 1 or 2 cells having DNA amount greater than 5c, and 74 cases where there were 3 or more cells having DNA amount greater than 5c. If manual cytology were to be used to refer all cases of HSIL and cancer to colposcopy and biopsy, 23 lesions that had to be removed would have been discovered (2 CIN2, 11 CIN3/CIS, and 10 cancers), for a sensitivity of 25.0+/-5.2% at specificity of 99.9+/-0.1%. If DNA assisted cytology were to be used instead, and all cases having 3 or more cells with DNA amount greater than 5c were to be referred to colposcopy and biopsy, then 50 lesions that had to be removed would have been discovered (10 CIN2, 15 CIN3/CIS and 25 cancers) for the sensitivity of 54.3+/-6.2% at specificity of 96.9+/-0.6%.
CONCLUSIONS:
The study suggests that screening for high grade cervical neoplastic lesions and cervical cancer by DNA assisted cytology could be implemented with minimal use of skilled cytotechnologists, at least in those countries where it would be difficult to introduce population based screening for cervical cancer due to the lack of availability of such skilled cytotechnologists.
Keywords
Cervical intraepithelial neoplasia (CIN), liquid based sample preparation, image cytometry, DNA ploidy, cytotechnologist shortage, cytology, sensitivity, specificity, invasive cancer
chenxiaoyan0313 离线
经验:265
1 楼    发表于2011-09-10 15:15:04举报|引用
检测宫颈癌和高级别的肿瘤性病变液基采样准备和使用自动图像分析的DNA测量的组合。
孙小蓉,汪建,Garner D, Palcic B.
摘要
目的:
要在那些人工阅读玻片是不可能的国家,因为缺乏足够的熟练细胞学技师细胞学医生和细胞学技师,建立DNA倍体的测量可用于协助细胞学医生和细胞学技师为人口基础的子宫颈癌筛查的方案。这一方案的目标是确定有临床意义的病变,即那些需要立即用临床干预去除的病变。
研究与方法:
一个共9905名妇女参加了这项研究。用宫颈刷取下宫颈的样本放置在固定液内。细胞学工作人员通过机器离心将细胞从粘液中分离出来,然后沉淀在载玻片上面。每个病例制做两张玻片,一张玻片是由巴氏染色方法染色,人工阅读细胞学,另一张玻片是由DNA的特定染色方法染色。后者的玻片是用来测定细胞核中的DNA相对含量。
结果:
共有876名妇女被随访阴道镜检查,活检可见病变或可疑的地方和病理组织学诊断为正常或良性病例459例,325例为CIN136例为CIN225例为CIN3/CIS,和31例为浸润癌。其中876例病例中,常规细胞学655例为正常或ASCUS,197例为LSIL16例为HSIL8例为宫颈癌。  DNA测量发现704例没有DNA含量大于5C的细胞,有12个细胞的DNA数量大于5C98例,有3个或更多的细胞DNA数量大于5C74例。如果将人工阅片细胞学的病例进行阴道镜检测和诊断HSIL及癌症​​23例进行活检,发现(2 CIN211 CIN3/CIS10癌症),敏感性为25.0 + / -5.2%,特异性为99.9 + / -0.1%。用DNA辅助细胞学检测的进行阴道镜检测,将有3个或更多的细胞DNA数量比大于5C50个病例进行活检,发现(10 CIN215 CIN3/CIS25癌症)敏感性54.3 + / -6.2%,特异性96.9+ / -0.6%。
结论:
这项研究表明,通过应用DNA辅助细胞学检查筛查出高级别宫颈肿瘤性病变和子宫颈癌的筛查方案。在这些由于缺少熟练的细胞学技师,很难引进熟练的细胞学技师为人口宫颈癌基础筛查的国家是可以实施,
关键词
子宫颈上皮内瘤样病变( CIN ),液体样品制备,图像分析,DNA倍体,细胞学技师短缺,细胞学,敏感性,特异性,浸润性癌
7
xiongyou..
苍山一吼
lyron
烈火
cyb1433
17250625..
tony5
chenxiaoyan0313 离线
经验:265
2 楼    发表于2011-09-10 15:15:46举报|引用
翻译有不够准确的部分,请大家原谅!
jani 离线
粉蓝豆:46
经验:1808
3 楼    发表于2011-09-10 20:49:24举报|引用
学习了  谢谢
咔咔1234
只有做你不会做的事 才能做会所有的事
小荷 离线
经验:12725
4 楼    发表于2011-09-12 18:41:43举报|引用
没有完美的个人,只有完美的团队
水中央 离线
经验:7190
5 楼    发表于2011-09-13 07:40:14举报|引用
好好学习一下
刀锋上的蚂蚁
6 楼    发表于2011-09-14 01:46:28举报|引用
CELL ONCOL         影响因子(IF)     4.169
小荷 离线
经验:12725
7 楼    发表于2011-09-14 20:35:02举报|引用
引用 6 楼 海上明月 在 2011-09-14 01:46:28 的发言:
没有完美的个人,只有完美的团队
xiongyouqin 离线
经验:73
8 楼    发表于2011-09-20 09:50:01举报|引用
值得学习,谢谢
村姑007 离线
经验:292
9 楼    发表于2011-09-20 19:19:23举报|引用
很好 啊,终于看懂了!谢谢!
宋茜 离线
经验:7
10 楼    发表于2011-09-23 10:07:42举报|引用
不错哦,看懂了。
冲天 离线
经验:1
11 楼    发表于2011-09-23 11:45:41举报|引用
wenyuan 离线
经验:15
12 楼    发表于2011-09-23 14:17:00举报|引用
通过翻译了解更多关于细胞学的背景知识,受益匪浅,支持。。。
lyron 离线
经验:17
13 楼    发表于2011-10-24 19:22:03举报|引用
很好的帖子啊~
又学习了一些专业英语的单词,期待看到更对类似的文章!!
wsyj 离线
粉蓝豆:1322
经验:932
14 楼    发表于2011-10-25 18:45:48举报|引用
请问可不可以理解:如果细胞病理诊断不够扎实的,细胞DNA可以补充。那细胞DNA误诊率有多少。谢谢。
老郎 离线
经验:19
15 楼    发表于2011-12-06 16:58:54举报|引用
学习了!获益匪浅啊。呵呵,支持兰丁,支持!
chenxiao..
xiaojianwangzi 离线
经验:184
16 楼    发表于2013-03-20 11:44:47举报|引用
zj123 离线
经验:182
17 楼    发表于2013-03-20 22:55:05举报|引用
 好贴!
王思雨 离线
粉蓝豆:51
经验:212
18 楼    发表于2015-03-14 21:41:10举报|引用
吴婵婵 离线
经验:449
19 楼    发表于2015-03-19 18:23:06举报|引用
吴婵婵 离线
经验:449
20 楼    发表于2015-04-16 13:04:22举报|引用
回复:20 阅读:6210
共1页/20条首页上一页1下一页尾页
