共2页/28条首页上一页12下一页尾页
回复:56 阅读:15252
B2229breast 髓样癌, yes or no?(cqz-26) 9-1-2009
楼主 发表于 2009-09-04 01:24|举报|关注(0)
标签:乳腺不典型髓样癌 基底细胞样乳腺癌
1 楼    发表于2009-09-20 06:08:00举报|引用
 This case may be called as 不典型髓样癌(AMC)based on the traditional criteria. Clearly the tumor cells demonstrate the focal infiltrating margins.
1. The term of medullary ca (MC) is confusing. The pathologic diagnosis is very subjective and interobservers are very variable. Basically many pathologists do not use the term any more. We did not make any diagnosis of MA in the past three years. Its prognostic implications are not certain.
2. In fact most of MA are triple negative and some basal-like marker positive, and belong to the category of basal-like ca, the same as most metaplastic ca.
3.We just call invasive ductal carcinoma for these cases because we do not give oncologists' impression that they have good prognosis.
4. For above case:
a. sentinel lymph node was positive
b. IHC: ER very focal positive: H score 4%, PR negative, Her2 score 2
 c. Her2 Fish 2.03 , equovical.
5. Finally, I released this case as:
Invasive ductal carcinoma, Nottingham histologic grade (NHG) 3 (tubule formation-3, nuclear degree-3, mitotic activity-3, total score 9/9).
6. Home message for this case: The use of the diagnostic term of MC is contradict now. At least you need to be cautious to make the diagnosis of MC.
I just mention how we handle these kinds of cases now. It does not mean it is the only correct way.
Just for your reference.
2 楼    发表于2009-09-20 05:31:00举报|引用
以下是引用abin在2009-9-4 23:23:00的发言:
 WHO 2003 关于髓样癌有5个诊断特征,本例都符合。
典型的MC具备五大形态特征:
    1、在超过75%的肿瘤范围内可见到合胞体结构。肿瘤细胞片状排列,常超过4或5个细胞的厚度,被少量疏松结缔组织隔开,可见局灶坏死和鳞状分化。
    2、极少有腺样或小管结构。
    3、间质内弥漫性淋巴浆细胞浸润是其明显特征,浸润程度各不相同。单核细胞少见或多得以至于把肿瘤细胞都掩盖了。可见淋巴样滤泡和/或上皮样肉芽肿。
    4、肿瘤细胞通常为圆形,胞浆丰富,泡状核,核仁1个或几个,胞核中等异型或异型显著,核分裂象多见,可见到不典型巨细胞。
    5、低倍镜下可见到肿瘤完整的包膜,在肿瘤周围形成压排性边缘与被压迫的纤维间质区相互混合。
    一些学者提出了被其他人接受的观点,即除这些典型的组织学特征外,导管内成分的存在也可作为一条排除其它诊断的标准,特别是位于肿瘤周边组织或在肿瘤内缩至小范围的区域。
    这些诊断标准,特别是肿瘤边缘情况,在实际中很难估计,这也可以解释在一些研究中MC诊断低重复性的原因。为了克服困难,人们又提出了一个简化的标准,即合胞体样生长方式、小管结构缺乏、淋巴浆细胞浸润及少量的坏死。这些被认为是MC最具重复性的特征,但是这一简化标准的有关预后的意义尚待评价。具有明显的合胞体结构但只具有其它2条或3条特征的MC通常被诊断为不典型髓样癌(AMC)。
3 楼    发表于2009-09-08 12:40:00举报|引用
 In fact there is no special treatment for basal-lik ca currently.
In our hospital we make diagnosis based on the following:
1. All invasive mammary ca: ER/PR/Her2(plus KI67)
2. All triple negative cases, we will do ck5 (ck5/6)/EGFR/ck14/ck17.
3. if above some of the markers are positive, we will call invasive ductal ca with basal-like phenotype.
4. For these classic metaplastic ca we will call metaplastic carcinoma and will not do basal-like markers for them. We will not call them as basal-like ca even though most of them will be positive for basal-like markers.
5. In the USA pathologists in many hospitals will not stain the basal-like markers for triple negative tumors. In other words it is required by CAP now.
Finally, we should know that basal-like carcinoma is a  heterogenous group of tumors.
事实上目前对基底细胞样癌没有特别的处理方案。
在我们医院,基于以下情况做诊断:
1.所有的浸润性癌:ER/PR/Her2(加KI67).
2.所有三阴性病例,我们将标记ck5 (ck5/6)/EGFR/ck14/ck17。
3.如果上面的指标部分阳性,我们称之为具有基底样表型的浸润性导管癌。
4.对这些典型的化生性癌我们称之为化生性癌并且不再对其做基底样标记。我们不诊断为基底细胞样癌即使它们中大部分基底样标记为阳性。
5.在美国许多医院的病理医生对三阴性的病例不做基底细胞样的标记。换句话说,现在它不是CAP(
College of American Pathologists
)要求必做的。
 最终我们应当知道:基底细胞样癌是肿瘤的一种变异形态。
              (quyibl译)
4 楼    发表于2009-09-06 21:01:00举报|引用
 Hope you will not become more confused after you read above abstracts. If we want to know a subject or topic really, we have to read related original publications. It is not enough to read some description in text book only.
5 楼    发表于2009-09-06 20:59:00举报|引用
Hum Pathol. 2008 Jun;39(6):857-65. Epub 2008 Apr 8.
Expression of BRCA1 protein in breast cancer and its prognostic significance.
Rakha EA, El-Sheikh SE, Kandil MA, El-Sayed ME, Green AR, Ellis IO.
Department of Histopathology, The Breast Unit, Nottingham City Hospital, University of Nottingham, NG5 1PB Nottingham, UK. emadrakha@yahoo.com
BRCA1 is a tumor suppressor gene which, when mutated, is associated with the development of hereditary breast cancers. In sporadic tumors, although inherent gene mutations are rare, loss of BRCA1, resulting from reduced expression or incorrect subcellular localization, is postulated to be important. The purpose of the current study was to examine the expression and localization of BRCA1 protein and to assess its prognostic value, in a well-characterized series of unselected breast carcinomas. We have examined BRCA1 in a series of invasive breast carcinoma (1940 cases) using tissue microarray and immunohistochemistry, to evaluate its expression pattern and to correlate this with clinicopathologic variables and patient outcome. In breast cancer, complete loss of nuclear expression was observed in 223 cases (15%) and cytoplasmic expression was found in 541 breast cancers (36.6%). Absent or reduced nuclear BRCA1 expression was observed more frequently in ductal carcinoma of no special type and medullary-like carcinoma and less frequently in lobular and tubular mixed carcinomas. It was also associated with high-grade, advanced lymph node stage, larger size, vascular invasion, negative estrogen receptor, progesterone receptor and androgen receptor expression, and positive p53 and P-cadherin expression, and with the basal-like class of breast cancer. Altered BRCA1 was associated with shorter disease-free interval. Cytoplasmic expression was also associated with development of recurrence and positive EGFR and HER2 expression. It showed an inverse association with survival particularly in low-grade, small-size, and estrogen receptor-positive subgroups. In the grade 1 subgroup, multivariate analysis with adjustment for other prognostic factors showed that cytoplasmic expression of BRCA1 was an independent predictor of disease-free interval. BRCA1 alteration may play a significant role in the development and progression of breast cancer. Immunohistochemical assessment of BRCA1 expression could provide additional clinically relevant information in routine classification of breast cancer.
6 楼    发表于2009-09-06 20:58:00举报|引用
J Pathol. 2008 Oct;216(2):141-50. Links
Refinement of breast cancer classification by molecular characterization of histological special types.
Weigelt B, Horlings HM, Kreike B, Hayes MM, Hauptmann M, Wessels LF, de Jong D, Van de Vijver MJ, Van't Veer LJ, Peterse JL.
Division of Experimental Therapy, The Netherlands Cancer Institute, Amsterdam, The Netherlands. bweigelt@lbl.gov
Most invasive breast cancers are classified as invasive ductal carcinoma not otherwise specified (IDC NOS), whereas about 25% are defined as histological 'special types'. These special-type breast cancers are categorized into at least 17 discrete pathological entities; however, whether these also constitute discrete molecular entities remains to be determined. Current therapy decision-making is increasingly governed by the molecular classification of breast cancer (luminal, basal-like, HER2+). The molecular classification is derived from mainly IDC NOS and it is unknown whether this classification applies to all histological subtypes. We aimed to refine the breast cancer classification systems by analysing a series of 11 histological special types [invasive lobular carcinoma (ILC), tubular, mucinous A, mucinous B, neuroendocrine, apocrine, IDC with osteoclastic giant cells, micropapillary, adenoid cystic, metaplastic, and medullary carcinoma] using immunohistochemistry and genome-wide gene expression profiling. Hierarchical clustering analysis confirmed that some histological special types constitute discrete entities, such as micropapillary carcinoma, but also revealed that others, including tubular and lobular carcinoma, are very similar at the transcriptome level. When classified by expression profiling, IDC NOS and ILC contain all molecular breast cancer types (ie luminal, basal-like, HER2+), whereas histological special-type cancers, apart from apocrine carcinoma, are homogeneous and only belong to one molecular subtype. Our analysis also revealed that some special types associated with a good prognosis, such as medullary and adenoid cystic carcinomas, display a poor prognosis basal-like transcriptome, providing strong circumstantial evidence that basal-like cancers constitute a heterogeneous group. Taken together, our results imply that the correct classification of breast cancers of special histological type will allow a more accurate prognostication of breast cancer patients and facilitate the identification of optimal therapeutic strategies
7 楼    发表于2009-09-06 20:57:00举报|引用
J Pathol. 2005 Nov;207(3):260-8.
Typical medullary breast carcinomas have a basal/myoepithelial phenotype.
Jacquemier J, Padovani L, Rabayrol L, Lakhani SR, Penault-Llorca F, Denoux Y, Fiche M, Figueiro P, Maisongrosse V, Ledoussal V, Martinez Penuela J, Udvarhely N, El Makdissi G, Ginestier C, Geneix J, Charafe-Jauffret E, Xerri L, Eisinger F, Birnbaum D, Sobol H; European Working Group for Breast Screening Pathology; Breast Cancer Linkage Consortium.
Marseille Cancer Institute, Molecular Oncology Department, UMR599 INSERM and Paoli-Calmettes Institute, Marseille, France. jacquemierj@marseille.fnclcc.fr
Medullary breast cancer (MBC) is a rare, diagnostically difficult, pathological subtype. Despite being high grade, it has a good prognosis. MBC patients have an excess of BRCA1 germ-line mutation and reliable identification of MBC could help to identify patients at risk of carrying germline BRCA1 mutations or in whom chemotherapy could be avoided. The aim of this study was therefore to improve diagnosis by establishing an MBC protein expression profile using immunohistochemistry (IHC) on tissue-microarrays (TMA). Using a series of 779 breast carcinomas ('EC' set), diagnosed initially as MBC, a double-reading session was carried out by several pathologists on all of the histological material to establish the diagnosis as firmly as possible using a 'medullary score'. Only MBCs with high scores, i.e. typical MBC (TMBC) (n=44) and non-TMBC grade III with no or low scores (n=160), were included in the IHC study. To validate the results obtained on this first set, a control series of TMBC (n=17) and non-MBC grade III cases (n=140) ('IPC' set) was studied. The expression of 18 proteins was studied in the 61 TMBCs and 300 grade III cases from the two sets. The global intra-observer concordance of the first reading for the diagnosis of TMBC was 94%, with almost perfect kappa (kappa) of 0.815. TMBC was characterized by a high degree of basal/myoepithelial differentiation. In multivariate analysis with logistic regression, TMBC was defined by the association of P-cadherin (R=2.29), MIB1 > 50 (R=3.80), ERBB2 negativity (R=2.24) and p53 positivity (RR=1.45). Copyright (c) 2005 Pathological Society of Great Britain and Ireland. Published by John Wiley & Sons, Ltd.
8 楼    发表于2009-09-06 20:57:00举报|引用
Eur J Cancer. 2009 Jul;45(10):1780-7. Epub 2009 Mar 14. Links
The prognostic significance of inflammation and medullary histological type in invasive carcinoma of the breast.
Rakha EA, Aleskandarany M, El-Sayed ME, Blamey RW, Elston CW, Ellis IO, Lee AH.
Departments of Histopathology and Surgery, Nottingham University Hospitals, Nottingham, UK.
The new gene expression molecular taxonomy of breast cancer places medullary carcinoma in the basal group. The basal group is considered to have a poor prognosis, but medullary carcinoma is considered to have a better prognosis than other grade 3 carcinomas. The prognostic significance of tumour associated inflammation, an important feature of medullary carcinomas, remains controversial. The aim of this study was to assess the prognostic importance of medullary histological type and inflammation in breast cancer. One thousand five hundred and ninety-seven patients who received no systemic adjuvant treatment and who had a median follow up of 9.5 years were studied. Results: Prominent inflammation was associated with high histological grade and with better survival [relative risk (RR) 0.57, 95% confidence intervals (CI) 0.44-0.74] on multivariate analysis. Typical and atypical medullary carcinomas (n=132) did not have significantly different survival and were grouped together. Medullary carcinoma did not have significantly different prognosis than grade 3 ductal carcinoma with prominent inflammation, but both had a better prognosis than grade 3 ductal carcinoma without prominent inflammation (P<0.0001 and P=0.03). These differences were independent of other prognostic factors. These results question the current separation of typical and atypical medullary carcinoma. Prominent inflammation is associated with a better prognosis, and may explain the better prognosis in medullary carcinoma compared with grade 3 ductal carcinoma without prominent inflammation. The good prognosis of medullary carcinoma emphasises the heterogeneity of basal-like breast carcinomas. Further studies are needed to investigate the difference in survival between medullary carcinoma and other forms of basal carcinomas and the role of inflammation in any such differences in behaviour
9 楼    发表于2009-09-06 20:56:00举报|引用
Breast Cancer Res. 2007;9(2):R24.
Identification of typical medullary breast carcinoma as a genomic sub-group of basal-like carcinomas, a heterogeneous new molecular entity.
Vincent-Salomon A, Gruel N, Lucchesi C, MacGrogan G, Dendale R, Sigal-Zafrani B, Longy M, Raynal V, Pierron G, de Mascarel I, Taris C, Stoppa-Lyonnet D, Pierga JY, Salmon R, Sastre-Garau X, Fourquet A, Delattre O, de Cremoux P, Aurias A.
Department of Tumor Biology, Institut Curie, Paris cedex 05, France. anne.salomon@curie.net
INTRODUCTION: Typical medullary breast carcinoma (MBC) has recently been recognized to be part of the basal-like carcinoma spectrum, a feature in agreement with the high rate of TP53 mutations previously reported in MBCs. The present study was therefore designed to identify phenotypic and genetic alterations that distinguish MBCs from basal-like carcinomas (BLC). METHODS: Expression levels of estrogen receptor (ER), progesterone receptor (PR), ERBB2, TP53, cytokeratins (KRTs) 5/6, 14, 8/18, epidermal growth factor receptor and KIT, as well as TP53 gene sequence and high-density array comparative genomic hybridization (CGH) profiles, were assessed and compared in a series of 33 MBCs and 26 BLCs. RESULTS: All tumors were negative for ER, PR and ERBB2. KRTs 5/6 were more frequently expressed in MBCs (94%) than in BLCs (56%) (p = 0.0004). TP53 mutations were disclosed in 20/26 MBCs (77%) and 20/24 BLCs (83%). Array CGH analysis showed that a higher number of gains (95 regions) and losses (34 regions) was observed in MBCs than in BLCs (36 regions of gain; 13 regions of losses). In addition, gains of 1q and 8q, and losses of X were found to be common to the two groups, whereas gains of 10p (53% of the cases), 9p (30.8% of the cases) and 16q (25.8% of the cases), and losses of 4p (34.8% of the cases), and amplicons of 1q, 8p, 10p and 12p were the genetic alterations found to characterize MBC. CONCLUSION: Our study has revealed that MBCs are part of the basal-like group and share common genomic alterations with BLCs, the most frequent being 1q and 8q gains and X losses; however, MBCs are a distinct entity within the basal-like spectrum, characterized by a higher rate of KRT 5/6 expression, a higher rate of gains and losses than BLCs, recurrent 10p, 9p and 16q gains, 4p losses, and 1q, 8p, 10p and 12p amplicons. Our results thus contribute to a better understanding of the heterogeneity in basal-like breast tumors and provide potential diagnostic tools.
10 楼    发表于2009-09-06 20:56:00举报|引用
Am J Surg Pathol. 2007 Apr;31(4):501-8.
Sporadic invasive breast carcinomas with medullary features display a basal-like phenotype: an immunohistochemical and gene amplification study.
Rodríguez-Pinilla SM, Rodríguez-Gil Y, Moreno-Bueno G, Sarrió D, Martín-Guijarro Mdel C, Hernandez L, Palacios J.
Breast and Gynecological Cancer Group, Molecular Pathology Programme, Centro Nacional de Investigaciones Oncológicas, Madrid, Spain.
It is not clear whether invasive breast carcinomas with medullary features (IBCMFs, atypical medullary carcinomas) constitute a specific phenotype of breast cancer that is of biologic significance. Because medullary features are common in BRCA1-associated carcinomas and these tumors frequently show a basal-like phenotype, we examined whether IBCMFs expressed basal/myoepithelial markers and had a basal-like phenotype. We studied the immunohistochemical expression of 15 markers in tissue microarrays containing samples from 35 IBCMFs and 39 grade 3 invasive ductal carcinomas (IDCG3s) of no special type. In addition, we analyzed EGFR, C-MYC, and CCNE gene amplification by fluorescence in situ hybridization, because the expression of these genes is known to be associated with the basal-like phenotype. We defined the basal-like phenotype according to the criteria of Nielsen et al as being those tumors that were ER/HER2-negative and cytokeratin (CK) 5/6- and/or epidermal growth factor receptor-positive. IBCMFs were more frequently hormone receptor- and HER2-negative, but had greater expression of proliferation markers and p53. In addition, IBCMFs more frequently expressed basal/myoepithelial markers, such as CK5/6 and P-cadherin. A basal-like phenotype was found in 62.9% of IBCMFs but in only 18.9% of IDCG3s. No differences in gene amplification were found between IBCMFs and IDCG3s, although C-MYC amplification was more common in tumors without a basal-like phenotype. The identification of IBCMF as an independent group of tumors could be of clinical significance, given the high incidence of cases with a basal-like phenotype, which is a group of tumors with different prognosis and chemotherapy response from those of IDCG3s of no special type.
11 楼    发表于2009-09-06 20:55:00举报|引用
Tumori. 2008 Nov-Dec;94(6):838-44. Links
Immunohistochemical analysis of ER, PR, HER-2, CK 5/6, p63 and EGFR antigen expression in medullary breast cancer.
Matkovic B, Juretic A, Separovic V, Novosel I, Separovic R, Gamulin M, Kruslin B.
University Hospital for Tumors, Zagreb, Croatia.
AIMS AND BACKGROUND: Recent publications of breast cancer classification based on gene expression profile analyses indicate that medullary breast carcinomas (MBC) may be considered part of the basal-like carcinoma spectrum made up of ER-negative, PR-negative and HER-2-negative cells ("triple-negative phenotype"). On the other hand, there are also data showing that a proportion of MBC and atypical MBC (AMBC) is ER, PR and/or HER-2 positive. Therefore, we have decided to immunohistochemically analyze ER, PR, HER-2 and basal/myoepithelial markers CK 5/6, p63 and EGFR expression in our archival paraffin-embedded MBC and AMBC samples from 48 patients. METHODS: Immunohistochemical evaluation of samples which were derived from patients operated on at our two hospitals between 1999 and 2005. RESULTS: Typical MBC was found in 39 patients and AMBC in 9 patients. The patients ranged in age from 32 to 84 years (median 55). Modified radical mastectomy with axillary dissection was performed in 30/48 patients (63%) while breast segmentectomy with axillary dissection was performed in 18/48 patients (37%). Metastases in axillary lymph nodes were observed in 15/48 patients (31%). ER positivity was present in 3/48 patients (6%), PR positivity in 8/48 (17%), and a positive HER-2 reaction was present in 14/48 patients (29%). CK 5/6 was positive in 20/48, p63 in 24/48 and EGFR in 8/48 patients. Adjuvant therapy was applied in all but 2 patients. Alive were 45/48 (94%) of patients. With the exception of PR expression, 39 patients with typical MBC and 9 patients with AMBC were comparable in the analyzed parameters. Positive HER-2 antigen expression in the analyzed sample was not found to be associated to a statistically significant degree with the MBC or AMBC histological tumor type, tumor size, axillary lymph node metastases, ER and PR status nor with patient survival. CONCLUSIONS: The data from our study seem to be generally comparable with the relatively scarce published data on clinicopathological parameters of MBC and AMBC.
12 楼    发表于2009-09-06 20:54:00举报|引用
Semin Diagn Pathol. 2004 Feb;21(1):65-73. Links
Medullary carcinoma, provocative now as then.
Eichhorn JH.
James Homer Wright Pathology Laboratories, Massachusetts General Hospital and Harvard Medical School, 55 Fruit St, Boston, MA 02114, USA. JEICHHORN@PARTNERS.ORG
The recent observation that studies of BRCA1-associated tumors contain a high proportion of medullary carcinomas and ductal carcinomas with medullary features has re-introduced pathologists to an old diagnostic problem. The term "medullary carcinoma" dates to the 19th century, but the modern entity was introduced in 1949 by Moore and Foote, who described a carcinoma with a lymphoid infiltrate, a favorable prognosis, and low frequency of metastasis. Almost three decades later, Ridolfi et al proposed specific criteria for diagnosis, resulting in an entity with an even more favorable prognosis and a lower incidence. The reproducibility and clinical relevance of the diagnosis have been questioned recently, and new criteria have been proposed and compared. The tumors typically express cytokeratin 7, often vimentin and S100-protein, but not cytokeratin 20. The usual ones are positive for p53 and negative for estrogen receptor, Her2/neu, and bcl-2. Medullary carcinomas express e-cadherin and beta-catenin more often than ordinary high-grade ductal carcinomas, and the former have genetic differences from the latter. The lymphoid infiltrate of medullary carcinomas is related to beta-actin fragments exposed by apoptotic cells. The present review discusses historical and recent developments and emphasizes diagnostic criteria.
13 楼    发表于2009-09-06 20:52:00举报|引用
以下是引用笃行者在2009-9-5 22:06:00的发言:
 非常好的病例!主要是两种意见:髓样癌;基底细胞样型乳腺癌。
我的观点是:诊断基底细胞样型乳腺癌应该有免疫组化结果的支持;诊断髓样癌必须1、形态典型。2、排除基底细胞样型乳腺癌。
Also for wfbjwt :Your reading is so fast.
Basically basal-like ca and medullary ca are two different calssification systems. We cannot say the dx of MA should exclude basal-like ca.
In fact most cases of MA belong to the category of basal-like ca.
I am pasting some related abstracts here.
14 楼    发表于2009-09-06 20:27:00举报|引用
 WHO 2003 关于髓样癌有5个诊断特征 as abin mention above.
Syncytial growth (large than 75%)
No glnadular structure
Diffuse lymphplasmacytic infiltrate
Nuclear pleomorphism, moderate to marked
Complete histologic curcumscription.
15 楼    发表于2009-09-06 20:20:00举报|引用
 Eur J Cancer. 1994;30A(12):1792-7.
Medullary carcinoma of the breast, prognostic importance of characteristic histopathological features evaluated in a multivariate Cox analysis.
Department of Oncology R, Herlev Hospital/University of Copenhagen, Denmark.
In this study of 136 breast cancers with medullary features (MC), registered in the Danish Breast Cancer Cooperative Group (DBCG) from 1982 to 1987, we confirmed the prognostic importance of a new definition of medullary carcinoma of the breast (MC newdef) which was recently proposed by us, deduced from a previous study of a corresponding tumour material (DBCG 77-82). However, the individual histological criteria did not have the same prognostic importance as in our previous study, although prognostic trends were the same. To further improve and validate the diagnostic criteria, we combined the two populations and performed a multivariate Cox regression analysis. In the final Cox model, four histological parameters retained positive prognostic importance: (1) predominantly syncytial growth pattern, (2) no tubular component, (3) diffuse stromal infiltration with mononuclear cells and (4) sparse necrosis. We propose that these criteria are emphasized in the histological diagnosis of medullary carcinoma of the breast.
16 楼    发表于2009-09-06 20:18:00举报|引用
  This is the important paper. In the past almost 20 y, people use this criteria for MA
Br J Cancer. 1991 Apr;63(4):591-5.   Pedersen L from Denmark did a lot of work on MA
Medullary carcinoma of the breast, proposal for a new simplified histopathological definition. Based on prognostic observations and observations on inter- and intraobserver variability of 11 histopathological characteristics in 131 breast carcinomas with medullary features.
Department of Oncology ONK, Rigshospitalet, Copenhagen, Denmark.
In a previous study of 131 breast carcinomas with medullary features, we evaluated the diagnostic inter- and intraobserver variation and its prognostic implications using the criteria of typical (TMC) and atypical (AMC) medullary carcinoma of the breast put forward by Ridolfi et al. (1977). We found a considerable interobserver variation as well as intraobserver variation, with significant implication on prognosis, and concluded that the histopathological definition of MC must be sharpened and simplified in order to increase the diagnostic reproducibility. In the present study of the same population of 131 patients with breast carcinomas with medullary features we have examined inter- and intraobserver variation concerning 11 histopathological characteristics. Furthermore, we have analysed the prognostic importance of these 11 histopathological features, and the prognostic implications of the observed inter- and intraobserver variation. Based on the observations, we have eliminated criteria with poor inter-/intraobserver agreement as well as those implying no or minimal impact on the prognosis. We propose a new simplified histopathological definition of medullary carcinoma of the breast (MC), retaining reproducible, prognostically significant criteria (syncytial growth pattern and diffuse, moderate or marked mononuclear infiltration). The prognosis of MC, based on this definition, is significantly better than those of infiltrating ductal carcinomas grade II + III.
17 楼    发表于2009-09-06 20:14:00举报|引用
 Breast Cancer Res Treat. 1989 Oct;14(1):91-9. onmouseout="PopUpMenu2_Hide();" href="javascript:PopUpMenu2_Set(Menu2605345);" target="_self">Links
Inter- and intraobserver variability in the histopathological diagnosis of medullary carcinoma of the breast, and its prognostic implications.
Department of Oncology ONA, Finsen Institute, Rigshospitalet, Copenhagen.
One hundred thirty-one breast carcinomas with medullary features, registered in the Danish Breast Cancer Cooperative Group from 1977-1982, have been histopathologically reviewed by two senior pathologists and classified as typical medullary carcinoma (TMC), atypical medullary carcinoma (AMC), and non-medullary carcinoma (NMC). Diagnostic criteria were based on those put forward by Ridolfi et al. and Fisher et al. The procedure was repeated with an interval of about one year by both pathologists. The diagnostic interobserver agreement was 72% with a Kappa of 0.55. The intraobserver agreement was 77% and 63% with Kappa values of 0.64 and 0.44, respectively. To see whether the observed inter- and intraobserver variability had any prognostic implications, diagnostic subgroups for both pathologists were analyzed with Kaplan Meier plots for recurrence-free survival (RFS) and with log rank tests. In the first evaluation pathologist 1 segregated a group of TMC with a significantly better RFS than for the NMC group, and pathologist 2 segregated a group of TMC with a corresponding strong trend. These findings could not, however, be reproduced in the second evaluation. The study indicates that the criteria of TMC and AMC as proposed by Ridolfi et al. need to be sharpened and simplified in order to reduce inter- and intraobserver variability. Larger studies with a control group of infiltrating ductal carcinomas are mandatory to elucidate the clinical importance of the diagnoses of Typical and Atypical Medullary Carcinoma of the breast
18 楼    发表于2009-09-06 20:11:00举报|引用
  Mod Pathol. 1995 Jan;8(1):31-8.
Medullary carcinoma of the breast: interobserver variability in histopathologic diagnosis.
Department of Pathology, University of Virginia Health Sciences Center, Charlottesville, USA.
To assess the interobserver reproducibility for the diagnosis of medullary carcinoma of the breast (MC), 53 previously diagnosed MCs were independently assessed by six observers for growth pattern, nuclear grade (NG), inflammation, tumor margin, intraductal component, and glandular features. Tumors were reclassified as MC, atypical MC, or infiltrating ductal carcinoma according to the histopathologic criteria of Ridolfi et al. (Cancer 40:1365, 1977), Wargotz and Silverberg (Hum Pathol 19:1340, 1988), and Pedersen et al. (Br J Cancer 63:591, 1991). NG was the most reproducible parameter, and tumor margin was the least, with consensus agreement by four of six observers for 49 (92%) and 26 (49%) of cases, respectively. Utilizing the histopathologic criteria proposed by Ridolfi et al., Wargotz and Silverberg, and Pedersen et al., consensus diagnoses were achieved in 37 cases (70%), 46 cases (87%), and 51 cases (96%), respectively. A consensus diagnosis of MC in all three systems was unassociated with tumor size, axillary lymph node status or overall survival (median follow-up: 89 mo). The consensus (or better) reclassification of 44/53 (83%), 35/53 (66%), and 27/53 (51%) previously diagnosed MC as atypical MC or infiltrating ductal carcinoma by the criteria of Ridolfi et al., Wargotz and Silverberg, and Pedersen et al., respectively, suggests that MC was previously over-diagnosed. While the scheme of Pedersen et al. is the most reproducible, additional follow-up information is necessary to determine the biological significance of this classification system. To minimize these difficulties in practice, pathologists should carefully adhere to published criteria and indicate the classification system utilized.
19 楼    发表于2009-09-06 20:07:00举报|引用
  Hum Pathol. 1988 Nov;19(11):1340-6.
Medullary carcinoma of the breast: a clinicopathologic study with appraisal of current diagnostic criteria.
Department of Pathology, George Washington University Medical Center, Washington, DC 20037.
Fifty-three cases of mammary carcinoma originally diagnosed as medullary carcinoma (MC) or infiltrating duct carcinoma (IDC) with medullary features were reviewed and reclassified using the strictly defined histologic criteria applied a decade ago by Ridolfi et al. Our study interval (1961 to 1982) allowed for a minimum follow-up of 5 years for each patient, with a mean follow-up period of 7.2 years. When reclassified, 24 tumors fulfilled the criteria for MC, 16 tumors were determined to be atypical MC, and ten tumors were found to be IDC; the observed 5-year survival rates were 95%, 80%, and 70%, respectively. These findings confirmed those of other investigators, that when specific criteria are applied, MC proves to be a form of mammary carcinoma with a favorable prognosis. However, we also found that when tumors were excluded from the MC category solely on the basis of in situ carcinoma, focal marginal infiltration, or a sparse mononuclear infiltrate, the survival rate of these patients was similar to that of patients in the medullary category. Thus, we propose that one of these criteria alone should not suffice to exclude the diagnosis of MC. On the other hand, tumors with two or more of these atypical features, or with extensive marginal infiltration, no mononuclear cellular infiltrate, and/or less than 75% syncytial growth, should be classified as IDC with medullary features. Typical MC with bland nuclei or a focal microglandular growth pattern only were not observed in this series; however, these findings should probably also cause a tumor to be classified in the IDC category. By dividing our cases into two rather than three groups, we found a statistically significant difference between the survival rates of 94% and 64% for MC (34 tumors) and IDC (14 tumors), respectively. Although the latter figure probably exceeds the survival rate for IDC without medullary features, the difference does not appear great enough to warrant a separate diagnostic category.
20 楼    发表于2009-09-06 20:06:00举报|引用
 Find some original paper abstrats about classification systems for medullary carcinoma (MA). They are similar, but with some difference. I am pasting some paper abstracts for some ones who have good English and are interested to this area.
Cancer. 1977 Oct;40(4):1365-85.
Medullary carcinoma of the breast: a clinicopathologic study with 10 year follow-up.
This is the first large study with follow-up and criteria of MA.
I will find the paper in libary and paste here later.
回复:56 阅读:15252
共2页/28条首页上一页12下一页尾页
